robrado974 1 Posted September 17, 2014 (edited) I had another go at fitting these tonight and still cant get it right , Rob has the manual atm but iirc when i looked last time it does not show you how they fit together , im not even sure if im fitting the right side ?, white to drivers door , black to passenger side .I presume the plastic part goes into the lock and sits on the outside of the door ?, not on the inside of the skin ,then push the door lock into it ?. Any help and info on how to fit these without me ending up in a straight jacket would be very helpful !!!.Everytime we think its where its supposed to be ,it just goes rigid , with no movement . Kind regards Rob Edited September 28, 2014 by robrado974 Quote Share this post Link to post Share on other sites
Wesleyvr6 10 Posted September 17, 2014 Can you get a pic of how you have it at the mo? Quote Share this post Link to post Share on other sites
robrado974 1 Posted September 17, 2014 Not really , it's such a small hole to get your fingers in , let alone take a pic . Out if everything I have done on this car in the last 7 years , this has to be up there in the top ten pita list ! Quote Share this post Link to post Share on other sites
robrado974 1 Posted September 18, 2014 I got a couple of pics today , there must be someone on here that can help . Im starting to wonder if i will have to drill out the rivets on the doors so i can gain access to these parts . Quote Share this post Link to post Share on other sites
swiftkid 1 Posted September 18, 2014 Well that plastic bit is only to lock and unlock so it only pushes the lever up and down. That bits the easiest bit, doing the door release I found an absolute pain in the arse. What are you struggling with exactly? Looks like you have it right in the top pic though Quote Share this post Link to post Share on other sites
robrado974 1 Posted September 18, 2014 (edited) Thanks for the reply , does the plastic bit fit into the lock and then get pushed into the door ? . I'm struggling to get the rods on to be honest . When I've managed to do it , its gone all tight with hardly any movement .ive released the locking pump to get more movement too .Its getting very tedious now ! Edited September 18, 2014 by robrado974 Quote Share this post Link to post Share on other sites
swiftkid 1 Posted September 18, 2014 I'm struggling to remember how I did it all. The door mech is massively fiddly, you have to prize out a catch from the mechanism and hook the rod from the interior door handle into it, the vertical rod will only need to sit in that plastic bit to move it up and down. You have to sort out the door catch first then push the lock mechanism into the plastic bit. If that all makes sense? Quote Share this post Link to post Share on other sites
robrado974 1 Posted September 18, 2014 It's a real struggle . What I'm trying to do is , push the plastic pivoting piece into the lock , insert the lock , then try and attach the two rods while trying to hold all the parts together at the same time . Quote Share this post Link to post Share on other sites
swiftkid 1 Posted September 18, 2014 Nah, the lock goes in last, the plastic bit should just sit in position so get the rods attached, then attach the interior handle rod, then lastly push the mech into the door and the plastic bit. Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted September 18, 2014 Am sure I attached the plastic bit to the rod that goes to door pin. The rod just sits in the hole and I think the plastic bit has a clip on it. I seem to remember fitting it then having to turn it to engage the clip. Then put the bottom rod that goes to interior handle onto the lock part. With it like that you can pull it outwards and slip the lever bit into the plastic bit. Dunno if that makes any sense but I have taken these bits off a few times and don't really remember it being too hard. I've got new bits to fit so will be doing both sides soon. Not sure how desperate you are to do it. But I can get pics and refresh my memory. Quote Share this post Link to post Share on other sites
robrado974 1 Posted September 18, 2014 Right , so when the plastic piece has the rods attached to it it's basically floating on the inside of the door skin . You then insert the door lock , so the metal prong slides into the plastic part . One rod goes up and the door pin screws onto it , the other goes down and into the central locking pump . So when you press the unlock or lock on the fob , both pins can pivot on the plastic part up and down .The long rod goes to the door pull , that's easy enough obviously . It's attaching both rods into the holes of the plastic part that is proving difficult . I guess perseverance is the key . Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted September 19, 2014 I thought only one rod went to the plastic bit. (Black bit in your photo) I fancy taking mine off to find out. It's been a while so I could well be wrong. Quote Share this post Link to post Share on other sites
robrado974 1 Posted September 19, 2014 There are two metal rods that connect to it Jim. One off the pump and the other to the door pin . Quote Share this post Link to post Share on other sites
swiftkid 1 Posted September 19, 2014 No, both go to that plastic bit, I know because when you push the door pin down it pushes against the vacuum of the pump. It's all coming back to me now Quote Share this post Link to post Share on other sites
Roger Chatfield 0 Posted September 19, 2014 (edited) Looking at this pic Rob i wonder if you are better off removing rod 8, attaching it to bit 7 and then poking it back up the hole rather than trying to connect it in the door aperture. Rog. Edited September 19, 2014 by Roger Chatfield Quote Share this post Link to post Share on other sites
robrado974 1 Posted September 20, 2014 No, both go to that plastic bit, I know because when you push the door pin down it pushes against the vacuum of the pump. It's all coming back to me now If it's all coming back to you , get over to my house and fix mine , Hull isn't that far , I can't come to you as mine is sorn . Seriously though yes this is what I've been trying to explain . Both rods connect to it , that's what maks it so difficult . Thanks for the pic Rog, very kind of you mate . I'm going to try again on Sunday ! Quote Share this post Link to post Share on other sites
mic_VR 3 Posted September 20, 2014 Judging by Rogers attachment it would appear only the door for pin rod attaches to the plastic part, and the inner door pull rod has a separate attaching point lower down? That or I'm reading that completely wrong! Quote Share this post Link to post Share on other sites
robrado974 1 Posted September 20, 2014 I think that's for a car , without central locking ? Quote Share this post Link to post Share on other sites
robrado974 1 Posted September 23, 2014 (edited) If anyone has a car that has the door cards off at present , could i ask you to spare a few minuets and have a look at how these parts fit together . Im at a total loss now . By the look of the diagram it shows the plastic part should go on to the prong on the latch and be inserted into the hole in the door ?. If i do this it wont go all the way in and the metal prong will not move easily. So ive tried the other way , but how an earth you are supposed to attach it i will never know . Also when i offer up the plastic part with the top rod in place it seems to be too tight against the door , i have two spare rods , when you put them together you can see that they are different , obviously left and right .Non of these seem to be right . Now i consider myself to be of average brightness , i certainly have alot of common sense ,i have removed a lot of parts on this car and replaced them on my own , but people on here are putting in engines in by themselves and im stuck on how to fit two pins and a door latch for gawd sake !!!,i do like problem solving and working out why something does not work weather its at work , home or whatever . You would not want to see a fellow enthusiast in a padded room rocking to and fro would you , im sure this poxy thing is going to send me there . Ok bit over the top ,but it is driving me round the bend . Any help would be much appreciated .edit , any more help I should say Rob Edited September 23, 2014 by robrado974 Quote Share this post Link to post Share on other sites
swiftkid 1 Posted September 23, 2014 You have removed the handle havnt you? Because that will stop the mechanism from going in as the slam lever rests on the door catch lever. Like I said though, you will not get the full lock mechanism in with the plastic catch connected because the interior door handle pull will be impossible to put on. What you need to do is connect the rods to the plastic catch, you won't be able to just move the catch up and down because of the vacuum pump. Quote Share this post Link to post Share on other sites
robrado974 1 Posted September 23, 2014 Hi swift , you are talking about the interior handle (pull) arnt you ? Quote Share this post Link to post Share on other sites
swiftkid 1 Posted September 23, 2014 No external handle Quote Share this post Link to post Share on other sites
neil20vtc 0 Posted September 23, 2014 I feel your pain I had this same issue when rebuilding my mk2 after it had been in the body shop they took all the bits off the old doors so I was left with figuring out these dam rods when putting the car back together it was 3 years ago though so can't remember it to well but remember struggling with that same bit I actually broke the golf equivalent of that black bit trying to get it to work and had to rob the black bit from a spare corrado door, I seem to recall pushing the rod with the small locating hook in line with the slot in the black bit then twisting it so it locates in the hole ! Sorry that's about all I remember well that and lots if swearing! Hope you get it sorted Neil Quote Share this post Link to post Share on other sites
robrado974 1 Posted September 23, 2014 Thanks Jeff , I will put your info to use , when trying again . Swift I will remove the handle , but the latch does fit straight on with it in place . I was speaking to Rob tonight who has Matt8v old car . He had chrome latches and wanted oem ones , he swopped these over without removing the exterior handle . Not that saying your wrong of course , I'm grateful for your help . Quote Share this post Link to post Share on other sites
swiftkid 1 Posted September 23, 2014 I'm just trying to think of things that may be causing you problems. You said the mech wouldn't go in so one of the things I thought might be causing you a problem is this. Oh and I just realised it's me and you diagnosing someone's car on Facebook lol Quote Share this post Link to post Share on other sites
