mooG60
Radiator Top Flange Leaking
Don’t over tighten them bolts or the captive nuts will break loose, then it’s pretty much goosed.
the seal is the o-ring as people’s have said. Try a slightly fatter top quality o-ring with some silicone grease to help it in.
Thanks for the advice everyone - Ive got some oe seals coming tomorrow - i will use a bit of silicon on the seal- if it leaks after that it must be the radiator warped side so hopefully a bit of RTV will cure that if it leaks again . I will post the seal that came off and compare to the OE one.
Edited by Keyo
