EssexG60 0 Posted October 20, 2022 All, By chance does anyone have any details from Autodata or equivalent showing the G60 Digifant ECU connector pin-out? Basically a breakdown of which pins go to which sensors indicating which values should be seen for the sensor in question. More importantly it can also show the direction of travel for the signal i.e. ECU to sensor or Sensor to ECU. I have an example of a print out for a Polo G40 from a different forum but was not sure I was allowed to share the screenshots. Quote Share this post Link to post Share on other sites
ger040 2 Posted October 20, 2022 Hello Is this what you need? - its from a vw dealers workshop manual Quote Share this post Link to post Share on other sites
EssexG60 0 Posted October 20, 2022 57 minutes ago, ger040 said: Hello Is this what you need? - its from a vw dealers workshop manual Thats Epic, yes what I was looking for. Just helps with further troubleshooting. The one I saw on the other forum also direction of signal etc but this will do. Do you have the whole book ? 😉 Quote Share this post Link to post Share on other sites
ger040 2 Posted October 20, 2022 Hope it helps I have a G60 myself and the VAG tech that set my car up was a bit hesitant to undertake the work as it had been something like 15 years from he last worked on them but once he seen the car he started to remember on its set up and quickly had it running a lot better The booklet is real old school when vw sent hard paper copies to all dealerships Yes i have the full booklet an ebay purchase long time ago. Hope you get the car running and if you need any thing from the booklet just ask Gerard Quote Share this post Link to post Share on other sites
EssexG60 0 Posted October 21, 2022 14 hours ago, ger040 said: Hope it helps I have a G60 myself and the VAG tech that set my car up was a bit hesitant to undertake the work as it had been something like 15 years from he last worked on them but once he seen the car he started to remember on its set up and quickly had it running a lot better The booklet is real old school when vw sent hard paper copies to all dealerships Yes i have the full booklet an ebay purchase long time ago. Hope you get the car running and if you need any thing from the booklet just ask Gerard Thank you Gerard, your help is much appreciated. Will drop you a message if need be, have a great weekend. Quote Share this post Link to post Share on other sites
Crasher 3 Posted October 21, 2022 This is Golf 2 PG but should be the same Quote Share this post Link to post Share on other sites
EssexG60 0 Posted October 21, 2022 (edited) Thanks mate, that looks very similar to the diagram I have from the Bentley, this is specifically for the Corrado PG engine. I merged 2 of the diagrams together to show the entire connectivity to and from the ECU. Edited October 21, 2022 by EssexG60 Quote Share this post Link to post Share on other sites
