  • entry
    1,505
Corrado Drivers window regulator cable repair
Bonebagger
Hi all
The driver's side window failed to lift a while ago so. after an epic struggle to get the motor and regulator arms out the reason for the item's failure was clearly the cable snapping, at the bottom end. Taking the cover off the winder, was also a revelation as the snapped cable had jammed the worm gear. (hence the problem dropping the window to remove the mechanism). The motor checked out as still fit for service.
All the parts are serviceable so I figure that a cable repair kit should sort the problem or failing that sending it to a professional
The 2 ends of the cable (lead barrels) fix into the drum in the winding mechanism. The cable engages with the arms via another lead cube fixed half way along the cable's length. I wonder whether 49 strand light yachting cable and crimps would fix it.........?? :scratch: Comments more than welcome
