    3,393
Part 2
Bfstrachan
11th November 2015
Replaced all windscreen scuttle trim and blower box cover
Fitted passenger under dash shelf
Fitted drivers side under dash fuse box cover
15th November 2015
Fitted new injector seals
Sprayed radiator cover plate
Degreased the head while manifold was off
New inlet manifold gasket
Throttle body cleaned
Refurbished 50mm inlet manifold fitted
23rd November 2015
Changed front and rear shocks to Bilstein B4's
Changed front and rear springs eibach 30mm lowered
New Ashley 4 branch manifold - issues clearing steering rack...
25th November 2015
Tracking/Alignment done - both front wheels out due to previous track rod replacement
26th November 2015
New genuine Febi front engine mount
Stripped and painted fan housing
Fitted stainless VR6 exhaust backbox
2nd December 2015
New rear engine mount - genuine Febi part
To resolve 4branch hitting steering rack - 10mm spacer between rear mount and engine bracket.
15th December 2015
Fitted new powerflex exhaust hangers
Fitted VR6 3 Spoke steering wheel
28th December 2015
Replaced the rear parcel shelf with uncut one
21st January 2016
Replaced new Radiator
Replaced new steering pump
Replaced new alternator
Replaced new water pump
Replaced thermostat & flange
Fitted new coolant hoses and clips
New auxiliary belts
New coolant
New oil cooler
New oil filter
Changed oil (143,000)
23rd January 2016
Replaced both fog lamps and indicator lenses
27th January 2016
Stripped out dash to replace heater matrix - quality 'Valeo' replacement
Refurbished the heater box - all stripped and cleaned with all new seals
New foam on all vent flaps - old foam disintegrated!
New blower motor fitted
8th February 2016
Replaced bonnet earth strap
Replaced rocker cover earth strap
New scuttle blower guard seal
New windscreen outer seal
Replaced heater control panel
9th February 2016
Front dash "pioneer' speakers
15th February 2016
Fitted new rear drivers side brake calliper
Renewed both handbrake cables
17th February 2016
Replaced centre trim - handbrake trim, gearstick trim, rear trim
Fitted new braided rear brake hoses
19th February 2016
Bled brakes
New FEBI locking wheel nuts
Replaced instrument panel: reading 138,100 miles - old reading 143,000
20th February 2016
Resolved spoiler issue - now works!
Resolved MFA all working now :)
26th February 2016
Replaced vacuum lines with silicone hoses
New cylinder head coolant flange and seal
15th March 2016
Repaired the drivers bolster with new foam
17th March 2016
Upgraded front brakes to 280mm brembo discs and Lucas 54 callipers
Fitted green stuff front brake pads
Fitted new braided front brake hoses
21st March 2016
Fitted rear "Hella" smoked lights
Fitted hose clips to engine breather hoses
Refurbished the alloys "gloss black"
Fitted New seal for idle adjust screw
Sprayed rear Corrado badge gloss black
22nd March 2016
Fitted new Ignition Coil
Cleaned the electrical connectors
New alpine front door speakers
25th March 2016
Drained and replaced gearbox oil
14th April 2016
Fitted repair panel around fuel filler cap.
Offside front wing, door, pillars and quarter panel re spray.
16th April 2016
Fitted 50mm forint splitter/valance to stop clearance issues.
22nd April 2016
Stripped head lining and sunroof panel
Fitted new antenna seal and whip part.
26th April 2016
Replaced sunroof seal with genuine VW one
Cleaned headlining with enzyme odour eater
