    3,393
Part 3
Bfstrachan
5th May 2016
Replacement sunroof headlining panel cleaned and fitted
Headlining replaced with new foam strips
Made a cup holder to fit in rear ashtray
29th May 2016
Fitted standard manifold and down pipe (from a 33,000 mile car)
Fitted new exhaust gaskets
New exhaust manifold brass nuts
Fitted stainless exhaust
Fabricated a flexi with twin hangers to join down pipe to centre section and make a better fitting system
Poly hangers
Fitted radiator cover and holding bracket
1st June 2016
Removed all glue residue from disintegrated under bonnet soundproofing
Rubbed down all rust and bubbling
Primed and sprayed treated areas
Fitted new under bonnet soundproofing
21st June 2016
Replaced the tailgate seal
Replaced the nearside outer window scraper seal
Fitted new pedal rubbers (including throttle)
Fitted new boot strut (nearside)
4th July 2016
Replaced the front drivers headlamp lens
Replaced the passenger fog lamp
Replaced the centre air vents
21st July 2016
Fitted Audi TT window wipers
6th September 2016
2.0 16v 9a engine
Degreased and sanded back
Bottom end painted black
3rd November 2016
2.0 16v stripped cylinder head
New tappets/followers fitted
New set of 17" KAHN alloys/Goodrich tyres
Roof sanded back and resprayed
Nearside resprayed
Rust removed and repaired Around windscreen
Nearside sill welding repair
11th November 2016
KR cams fitted
New timing chain
New timing belt and tensioner
New oil pump
New oil pump baffle plate
New sump seal
New camshaft seal
12th November 2016
New Bosch metering head
New stainless fuel leads
Refurbed fuel distributor
New Bosch injectors
New banjo fuel fittings
New metering head seal
