    3,393
Part 4
Bfstrachan
24th November 2016
New gearbox mount
New rocker cover seals
New starter motor
New clutch slave cylinder
25th November 2016
New LUK clutch kit
New release bearing
New crankshaft seal
New flywheel bolts
New clutch bolts
8th December 2016
New lower control arms
New inner roll bar bushes
New roll bar drop links
Anti roll bar sanded bare and re-sprayed
New ball joint nuts and bolts
Crossmember sanded and re-sprayed
Crossmember cover plate sanded and re-sprayed
Front bumper re-sprayed
Slam panel front edge re-sprayed
20th December 2016
New driveshaft seals
New driveshaft bolts
New inlet manifold gasket
New exhaust manifold gaskets
16th January 2017
Flushed brake system and bled brakes and clutch
New HEL stainless braided clutch hose
Wheels aligned and tracking set
New oil (142,100 miles)
New coolant
New power steering fluid
25th January 2017
New FAG front wheel bearings (both sides)
New front top mounts/bearings (Lemforder)
New front brake backing plates
4th February 2017
New power steering auxiliary belt
Vw Centre caps
MOT failure 4th February 2017
New Rear shock absorbers (Bilstein B4's)
New Brake pressure regulator
Drivers side sill repair - damage cut out and new plate welded in
Drivers sill sprayed and underside stone chipped and sealed
New drivers inner driveshaft boot
MOT Passed 15th February 2017 :)
27th February 2017
Visit to Ricky Gauld.
Set the ignition timing
Set the fuelling
20th April 2017
Fitted new Fuel pump
Fitted genuine VW ARB drop links
28th April 2017
Suspension overhaul:
Front top mounts replaced
Eibach springs all round
Tracking and Alignment done
21st May 2017
Cylinder head rebuild:
KR head - ported and flowed
Head gasket
Oil valve stem seals
Valves ground and seated
Rocker cover seals
New head bolts
New timing chain
New camshaft seal
New coolant flange/seal
Oil changed (144,000)
