    3,393
Part 5
Bfstrachan
25th May 2017
Fitted '16vDaves' shortshifter
1st June 2017
Replaced the drivers door card
Fitted '16vDaves' handbrake tunnel bracket
Fitted good condition used centre trim
25th June 2017
Fitted new fuel pressure distributor
Set fuelling and idle speed
Huge difference in fuel economy!
3rd July 2017
Oil change (145,000)
New spark plugs
New coolant expansion cap
19th July 2017
New oil cooler
New oil filter housing gasket
New oil sump and seal
New sump bolts
New coolant
Oil changed ( Shell Helix 10-40)
Oil filter (genuine Vw)
31st July 2017
Oil leak issue resolved - finally!
Revealed the oil filter housing
Replaced all oil sensors on filter housing
Replaced the fuel tank holding straps (new bolts)
