    1,745
Ollie's VR6 - First blog entry
OllieVR6
So, inspired by Alex's member thread, I have decided to centralise all my 'to-do' lists so you lot can read it and I can keep on top of it. My Corrado has pretty much been off the road for two years now but in 2011 I AM going to get it sorted! I will do a second entry with the history of the car later in the week, and I will include some pictures. I am going to try and be organised by sorting my list into sections, I'm hoping I can group them together so that all the bits in each group will be completed at the same time. So here we go:
Section 1 - Starts 7th March
New front tyres
New suspension top mounts
Fit coilovers (need to source a C spanner!)
Oil & filter
Air filter
Spark plugs
Coolant change
Charge battery
Investigate exhaust leak (probably down pipes)
Run VAG-COM diagnostics
Free drivers side central locking (stuck locked)
Section 2
Find & fix coolant leak
Check CV joints
Check wheel bearings
Check all lights
Check earth straps on bonnet, throttle body, and gearbox
Check vacuum pipe to ECU box
Check power steering fluid level
Check clutch fluid level
Clean the idle valve and throttle body
Fit new window rollers
Strip out factory alarm
Install headlight switch fire prevention fuse kit
Gear box oil change
Section 3
Fix windscreen leak
Reinstall interior
Section 4 (Brakes)
288 front brake upgrade
Mk4 rear brake upgrade
Braided hoses
New fluid
Check handbrake operation
Check brake lines for signs of damage or corrosion
Check rear break compensator valve is operating correctly
Section 5
Tint rear lights red
Buy and fit rightclick keyless entry system
Grease seat runner, door handles, door latch
Section 6 (Stuff on the list with no time scale attached - misc items)
New filler cap gasket - 535 862 287
New ignition switch
New fuel pump, crank sensor and coil pack
New rear tyres
Fuel filter
Lupo or TT wiper upgrade
Get spare key cut
Check Opertation of Spoiler and lubricate with a dry teflon based grease
Check Window operation and grease guides if needed
Check Sunroof operation and condition of seal, and drain holes
Check Underseal (under car)
Check plugs 1 and 6 periodically for oil fouling
Slacken the serpentine belt and spin the tensioner pulley, checking for stiffness
Check serpentine belt for cracking and splits
Listen to the gearbox side of the head for chain slap noises
Periodically check the lower half of the front engine mount for splitting
Buy and fit audioscape door pods - General audio sort out
I know that some of these jobs will take two minutes whilst others will take hours/days and the list will obviously evolve over time but it's a pretty good starting point. If anyone is wondering, a few items on this list came from the old servicing guide in the wiki.
Thanks for reading.
