    30
    2,566
11th May 2008, The Forced Induction 8V Thread
G60_Marc
After having owned a white 91 corrado G60 for a while the charger gave out (on 200,000 miles, 1 owner from new, original charger!) and also a cyclist ran into the side of me denting the rear quarter panel. As it is high mileage and a bit tatty i decided to break her up for parts and a few weeks ago i bought this http://the-corrado.net/showthread.php?17194-Monkeys-IHI-G60&highlight=monkeys+ihi
since owning it i have re-wired the engine bay, slapped on some red and clear rear in-pros, checked all engine sensors isv etc and i adjusted the timing to stop it pinking.
It runs really well :norty:
Plans for summer:
440cc injectors
16v fuel pump
Upgrade fpr
re-map
Oil cooler
Gearbox
The gearbox in the car is standard and currently at 150,000 miles, problem is it whines a little under de-acceleration . I have recently bought a new 02A gearbox code ATN and am thinking of putting some CTN ratios into it so the car has longer legs, it needs them!
