    30
    2,566
1st July 2008, So far...
G60_Marc
A few things ive done so far...
G12+ coolant.
oil.
new battery.
new front tyres.
ebc green stuff all round.
new headlights.
new fog lights.
new fk grill.
new inpro red/crystal rears.
new oem clear side indicators.
new oem chrome rear vw badge.
new ariel.
stainless steel polished battery cover.
chrome polished inside door handles.
carbon fibre gauge pod in cubby hole.
carbon fibre radiator cover.
inxx bonnet lifter.
alloy strut top caps.
10mm blue 4 core HT leads (from inters)
new w5dpo spark plugs.
new knock sensor.
tidied up engine bay wires.
new expansion tank.
polished up all air intake pipes a little.
new rockford fosgate ice install.
mtx stealth shelf.
installed greddy boost controller above steering wheel.
new afr guage.
altered timing (it was pinking really bad)
added an extra exhaust hanger to stop flexi banging on steering rack.
overhauled calipers.
cleaned and undersealed inside all wheel arches.
fixed rear number plate surround.
Fixed quite a few faults, switches, electric mirrors, handbrake tunnel surround etc. lots more
Next up is a new windscreen and gearbox, the one in it whines when off throttle. I have a nearly new (2000 miles) 02A AYN code box to go in for now, still pondering CTN tho.
UPDATE:
Installed a brand new gearbox. A friend bought it new from vw but ran it with low oil which burnt out the input shaft bearing. I bought it off him and replaced the bearings
LINK TO PICTURES OF STRIP DOWN AND BUILD UP
