    1,626
coil pack advice
jimmymcq
help guys. Ive been having a bit of a cold start and rough idling issue and i'm thinking its the coil pack. I have removed the pack with a view to maybe trying the epoxy fix and discovered that there is no cover on the pack (covers the buzz bars going from the pin socket to the actual coils) hope that desc makes sense. I'm going to seal the pack with resin anyway and see if it works but wonder if anyone has a broken pack with the cover that i could potentially buy or your thoughts as to wether its required or causing the problem.
thanks for any help
james
