Fez
48 -
0 NeutralAbout Fez
- Birthday 07/20/1981
Cardiff, South Wales
Music & Corrado's
DJ
how do u save ur pic?
How do you get these bad boys out as one of my bulbs has gone. Cheers, Fez
Guys, Another quick one for you... Is the distributer driver of the valve timing belt??? Thanks, Fez
yeah but it was a while back and i lost my receipt. GRRRRRRRR any otha answers.
thanks for the info. Luckily enuff the charger doesn't need rebuilding. the bad rumbling which i thought was the bearing ended up to be the water pump on closer inspection. Thanks for the recomendations anyways :D
Don't supose anyone has a picture/diagram of how the V Belt sits over the tensioners and pulleys of a C G60. Cheers Fez :D
leon, thanks for that, have you got a web address for JMC. Also, are Jabba Sport any good?
Ok, looks like I'm not gonna get hold of a second hand charger in the timescale I require. Please can you help me with some sites of companies who can do the rebuild. Also, Any recommendations would be helpful too. Thanks, Fez :D
Anyone know if a US spec G60 supercharger off a synchro Passat will fit a UK spec 91 G60? Need an answer if poss by 830am tomorrow morn (08/07/06). Cheers guys, I know you wont let me down :roll: :wink: :D
reason being a garage changed my gear box and they took the battery out to charge it. when they clamped the battery back in they clamped the passenger side headlamp loomp with it. When I turned the main beam on I was greeted with a big cloud of smoke and only side light action. Full beam does not work either. I've since re wired the headlamps back to the fuse box and all fuses are fine. So i think either: The fuse box is fooooked The lamps are connected to a relay in some way and thats foooked or the on dash sidelight/main beam is foooked. Any suggestions gang? Any help greatly apprieciated.
Does anyone know which relay controls the headlamps in a 91 C???
sounds like a plan :lol:
