TITAN
75 -
0 NeutralAbout TITAN
cheshire
G Y M
maintenance controller
OK many thanks i need an ECU big time cheers dude
Can anyone tell me will a VW Golf Rallye G60 Syncro ecu Mk2 Gti Driver ECU unit will work on a 1992 corrado g60 ?? . cheers
Has anyone fitted a kent cam shaft kit to there g60 ? and if so was there much more power , or can anyone tell the best cam kit to fit please. Cheers
Guys i was thinking of fitting a 2ltr gti golf mk3 engine in to my G60 and putting the super charger on it swopping all the bits over but i know the compression a lot higher on the 2 ltr but could i fit the the crank from my G60 1.8 to the 2ltr engine to lower the compression??? or is this just a wast of time and effort ????? cheers. :grin:
SPELLING NEVER BEEN STRONG WITH ME THANKS FOR THE TIP THOUGHT FULL STOP! )
OK every now an then as ma driving the engine cut out like there is no fuel then cut back in the other night engine cut i pulled over was turning over not starting pull of fuel pipe this was pumping fuel through messed with the inj-relay this was clicking but still woould not start left it for a bit about 7 mins restart fired up got out my house cut out next morning still would not start recheck fuel was pumping through and it was pull the relay out opened it up checked for any heat damaged was ok no smell of burning refited but still not working messed about with wiring loom then it startted not sure why and now as am driving still cuts out but strait back in it can not be a blocked fiter? i just dont get it arrrrrr i just can not trust using the car !!!!
ANY1 PLEASE HELLLPPPPPP IT :salute: :(
GUYS A MY CORRARD G60 keep cutting out then firing back up iv noticed that when I removed the fuel cap am getting pressure so am Thinking the fuel tank not breathing so vac - pressure building up causing Temp fuel stoppage or could I be very wrong also iv messed around with the inj--relay At the same time see if that working can anyone. cheers
yer full lenth from volkbits on line to tell the truth a iwas after a new grill but like a muppet i pick out the wrong thing doh! :brickwall:
Guys got an eye brow spolier iv never fitted one or looked at a corrado with one can anyone tell me are they easy to fit i need to paint it first ! i got some self tappers with it ?? but no fitting instructions :shrug: cheers .
guys i have seen a mk3 golf 8v gti enging 2ltr look like the same block off my k reg corrado g60! , what i want to do is get the 2 ltr block and swop all the G60 parts over to the 2ltr engine would this be a proble and would the ecu from the G60 unit work ok??? cheers all !! :D
SORTED it was the inj-relay causing the fault thanks for the help guys :D
