gus16v
8 -
0 NeutralAbout gus16v
- Birthday 10/17/1980
Milton Keynes
Engineer
any ideas please as it's really cold and the heater only works on postion 4!!!! cheers :)
most VW pulleys have shims as a way of achieving belt tension rather than the conventional tensioner arm an bolt. The one in question I think is a spacer shim between two pulleys water pump and alt belts run on it!
it looks like the water pump pully shim is worn and the pully is rattlling in the front pully, need to get a shim sorted, should get rid of the noise.
What is the largest front brake disc I can run on my standard 1.8 16v G reg corrado calipers?? Cheers
noise is coming from the right hand side
My 1.8 16v corrado has a rattle from the drivers side engine bay, could this be cam belt tensioner or water pump pulley or anthing else?? The water pump pulley has some side to side movement but not sure if that's it. If it is the water pump pulley will this fail or is it ok to drive with till it can be fixed??? ant help would be nice, cheers :D
yeah, not to my taste either, but not sure what I can get for it thats not a complete a**e to fit!
Hi there, I have just bought my 1.8 16v corrado and I'm loving it. Hope I can get some useful info from this forum.
