rocket
11 -
0 NeutralAbout rocket
- Birthday 05/07/1980
ok still having problems getting the fans to kick in when the ignition is on thought about one of these will this cause any problems any were else ??? http://www.rallydesign.co.uk/catalog/pr ... ts_id=3449 or http://cgi.ebay.co.uk/ENGINE-COOLING-FA ... dZViewItem
right got my fan and got my hose's so i put it all together and bridge the connector getting nothing at the fan end no 12v on any wire's the old fans did work but only on after run , thought this may have been down to a blown rad ???? any body help ???
after some Corrado Vr6 Coolent hose's to finish my project off like samco etc..., rang a couple of places and they say it will take 6-10 weeks :( does any body know if theres a shop that have them in stock ???
Slime line fans you not heard of them there the new rage .... daft question what am looking at with the multi meter ????
im doing a mk2 conversion and im installing a corrado rad with a slimline fan , i have searched the forum and i have found that speed 1 , 2 will be ok but how do i wire it up to run in this setup ???? do i nip the end off the wire that went into the vw fans and wire it up to that if so any ideas which pins ???? need to go to which wires ???
Quickest car you've been in, owned and most interesting....
rocket replied to NickVR6's topic in General Car Chat
fastest car ive been in and owned lotus 111s but i have to say the fastest thing i have owned is an R1 and my current zx6 (not for out right speed but just how it handles) -
so has any one got one Dont fancy taking the risk of making it fit as theres a tiny bit of weight on that mount
cheers for the info will ring the bar stools who sold it me up
did your mount sit in a cup i have been searching around to see if the crossmember is right and found this pic of one this seems to have a cup section so the mount drops in ??? seems weired if it is not correct that the engine lined up on the standard mount it had
wonder if you can help im currently doing a mk2 vr6 project i bought a crossmember and was told it was a vr6 corrado i have tried the engine in with the crossmember and the mount that came with the crossmember and it seemed to sit in fine .. i have then bought a vf engineering mount for a mk3 vr6 which fits the corrado as well (stated on the fitting instructions) i tried to fit the mount last night and it does not fit ??? removed the old mount completely from the crossmember then tried to fit the vf mount and the thread is not long enough to go through the hole and out the other side ?? Please help .... can not see how it is going to fit , is the crossmember the wrong one ??? seems strange if the engine was lined up if is it or do you have to moddify the vf mount ???
looking around and these seem to be the best mounts for my vr but can not seem to any suppliers ???
