hardyruth
11 -
0 NeutralAbout hardyruth
Dundalk, Ireland
thanks! Now my upper coolant hose is leaking...just ordered a new one but can't get it until Thursday, so the car is off the road for a few days!
yeah i'll try that then. is it just the blades i need to get or is it the whole motor?
yeah, they are really bad. so is it from any year? can i just order them from vw or gsf?
thanks, it was the fuse. you know the way the wipers on the corrado are crap, i've heard that you need to change them to lupo wipers but i don't know which model and is it easy enough to do?
thanks but unfortunately i'm in Ireland. I'll check the fuse first and see if i've any luck
thanks for the quick reply. where can i get the repair kit or this 'water guide plate'?
i've just recently bought a corrado and i'm having the same problem, my wipers are crap. i've read loads of comments about putting lupo wipers on instead. can you give me some advice on how to do this and where i should buy them (is vw the best place)?
the arm on my sunroof is broken and therefore it does not close properly. it will close flat on the right hand side but because the arm with the pulley is broken on the left hand side it won't close flat. so my sunroof is sitting at an angle and the rain gets in! i have managed to force close it a bit more to keep most of the rain out but it looks terrible. the electrics are working fine so it's just the mechanics of it. if i buy a new sunroof are they easy to replace, they seem very hard to get at. does anyone have any suggestions?
hi, i'm having a similar problem but my spoiler will not rise at all. it used to work and then one day it just stopped in the middle of rising. i can't hear any noise coming from the motor so i don't hink it is jammed. i have tried to find the fuse for it but don't know where it is located, can anyone tell me? and if it's not the fuse could it be that i need a new motor? any help would be much appreciated, i have would it up manually but it's just not the same!
thanks but i actually got it working, seemed to be the 3 parts from the censor down to the bit in the gear box.
i recently bought a 92 corrado but the speedometer is not working. i replaced the sensor as part of it was broken off and stuck in the rod. so i then replaced the rod aswell (that goes into the gearbox) but unfortunately it is still not working. i have already checked the connector on the instrument panel and it's fine. i'm really at a loss, i need to get it working...has anybody any suggestions?
