vdub_dan
8 -
0 NeutralAbout vdub_dan
Yea idles quite smoothly, had a look at the boost gauge pipe.. It's on the the little nipple comin off the servo pipe....
Yea I've changed the ecu for the g60 one.. Ive already taken off the pipe and it does blow my hand, and same with the linkages there all fine and in full working order... As for the boost gauge I'll have to check when I get home to be exact but it's plugged in around by the isv..
When it was in the other car it was reading about 1bar.. Using the same gauge in this car it's now reading zero.. At the minute checking in neutral but I had taken the car out and it's flat.. There jus no power.. Yea I hear the charger, whines like a gooden.. Jus don't understand coz there's not really alot that will stop a G boosting is there?? Apart from leaks, boost sensor and a knackered charger??
Well I took the donor car out and all worked perfectly.. (shell was rotten that's why I taken it out) and now it's in this one there's just no go, I have a boost gauge in there and it's showing 0 bar when you put your foot down.. That's the thing I have no service history with the engine or charger but I know it was workin in the other car..
Hi all, I've recently put a G60 engine in my 1.8 16v including dash wiring loom and fusebox.. But my problem is that it's not boosting I've checked for leaks and checked the charger it's seems to be working ok.. I've also checked the linkage on the throttle and the return is fully closed when suckin and open when throttle is closed.. Have you any ideas or suggestion as to what it is or what I can do?? Thanks in advance, dan
Sound I'll get them checked then
Oh and the wing mirrors are dead too
Hi all, I've recently bought a corrado that needs abit of tlc.. Couple of electrical problems and bodywork, but I wanna get the electrics done first. The first thing I did with these problems was check the fuses and there ok.. So first of all the central locking doesn't work, it hasn't got a fob only the key and it doesn't work with that.. Second thing is the blower, it doesn't work on 1,2,3 or 4 Any suggestions on repair or replace to get these working would be greatly appreciated Thanks, dan
