jackvine
44 -
0 NeutralAbout jackvine
Hi I've tried PMing but for some reason I can't seem to send
Hi is the G60 still for sale ?
Hi I have a spare, it came off engine thats done 120k been rebuilt once, but have no paperwork, no porting just standard charger, would probably benefit from a rebuild and checkover, yours for £325 plus postage
Ok thanks for the info, I just need to get another G60 badge for the Rear then
Hi Im trying to but my G60 back to standard, what badges are actually fitted? There should be a G60 Badge on the Front grill and back, but should there be a supercharged badge on the back ?
12.6 Volts ? You need to do a current reading with the engine off, and see how many amps are being drawn. You can't just put the meter across the battery it needs to be put inline with the positive terminal. Normaly different connections on your multimeter
Have you put a amp metre on it when the engine is off to see what the current is being drawn ?
So even when the battery is disconnected the battery is draining?
Thanks, didn't think about liquid metal, will get some and give it a go ! How did you find removing the bearing oil seals ?
Hi All Just stripped down my G Lader, have found one of the scrolls on the displacer is slightly damaged on the edge, also found that the apex seal and spring are missing from that one! Do I continue rebuilding it or try and locate another displacer ? The rest of the charger is in perfect condition.
Mine before I cleared it this morning
When you first got it did it run fine? Mine did this and I removed the throttle body and totally cleaned it and adjusted the throttle cable, now idles fine. Also try pulling the throttle pedal back see if the butterfly is getting stuck open slightly.
Doesn't look right as a club sport ! Should be yellow ! or white and it has a rear wiper which was deleted on the club sport model
Yeah think they look better, meant to be Porsche Cup 2 replicas! cost me £120 from ebay with tyres, but I think 17" may be to big as steering feels bit vague now ! Really thinking about converting it back to a G-Lader stage 4, as its got the FMIC it should produce some good figures I hope !
Got some new used wheels for my G60, not sure though 17" might be to big!
