Sandy 0 Posted October 11, 2004 Hello Folks, Anybody know the correct tyre pressure for 215/35/18 tyres ?? thanks for any help in advance Quote Share this post Link to post Share on other sites
Supercharged 2 Posted October 11, 2004 As far as I know, Pressure is pressure, the weight of the car is the same so just run whatever you did before in the old tyres and adjust from there to counter oversteer/understeer... I usually run 35 in the fronts and 32 at the back in the summer and a couple of PSI less in the winter... I suppose the profile you are now running will be less 'forgiving' so may want to set it to a slightly higher pressure than previously. Quote Share this post Link to post Share on other sites
