Rob_B 0 Posted October 11, 2004 does anyone know what the codes when the MFA is set into a sort of servive mode mean? i.e. set MFA into position2, hold end button, switch engine off and on again whilest holding this button, release the button and press again. there are about 7 different codes. i know one of them tells you the boost pressure, not sure what the others refer 2 Quote Share this post Link to post Share on other sites
vr6storm 0 Posted October 11, 2004 if you do a search on here you'll find the info you need :wink: EDIT...........have a look at the 6th post down http://the-corrado.net/.archive/forum/viewtopic. ... ight=#2536 :wink: Quote Share this post Link to post Share on other sites
