task 0 Posted October 15, 2004 only when I let it idle, and it drives kinda rough (the engine noise is too high for the rpm its showing)this is the best i can describe it. I measured the Air/fuel ratio and it was running rich. the is no air leak and the hose that goes to the Ecu is exactly 100cm long, any suggestion on how to stop the shaking? :roll: by the way its a g60. Quote Share this post Link to post Share on other sites
Henny 0 Posted October 15, 2004 sounds like it's mis-firing... take each plug lead off one at a time in turn while it's idling and see if you can identify which one makes the least difference... Then check the lead to make sure it's OK, check the dizzy cap and rotor arm to make sure they're OK, and check the plug to see if that's OK too... Post back with the results... 8) Quote Share this post Link to post Share on other sites
