black66 0 Posted October 16, 2004 My passenger door on my 94 VR has decided not to unlock. Doesn't unlock with remote. Doesn't unlock when key is turned in the door. The door pin will raise maybe 5mm and then drop back down. I cannot even pull the door pin up physically. I can hear the pump, and central locking is locking drivers door, petrol flap etc... Any ideas? Or suggestions on how to remove the door panel with the door shut? Cheers Quote Share this post Link to post Share on other sites
Supercharged 2 Posted October 16, 2004 Sounds like the rubber diaphram in the lock actuator is worn or leaking.... but if you can't pull it up either??? I have heard its possible to get the door card off without opening the door but not exactly sure how! Quote Share this post Link to post Share on other sites
