emmafwa 0 Posted October 20, 2004 I fitted a new stereo a few weeks ago and since then my active spioler doesnt work! It works manually but the active part is no longer true. Ive read another person with the simmilar problem and someone suggested looking at a blue wire behind the ICE, where the hell is that???? Do you think Ive buggered it up by fitting the radio myself? Am I in the right place for a blue wire?? Help will be very much appriciated. Emma Quote Share this post Link to post Share on other sites
Henny 0 Posted October 20, 2004 You're in the right place... Take out the head unit again, and you'll find a blue wire with a white stripe on it coming out of the car's wiring loom... disconnect this from whatever it's connected to and your spoiler will probably start working again... 8) Quote Share this post Link to post Share on other sites
emmafwa 0 Posted October 22, 2004 Ok now I did what you said and I found two blue wires with white stripes one was connected to something and the other had insulation tape round the end of it ( I definately did not do that), so I disconnected the other and just left it lose, but it still isnt working. Do you think the "insulation tape" wire has gone wrong futher down the line or should I just take it to the pros' Thanks very much for the help. Quote Share this post Link to post Share on other sites
quicksilver 0 Posted October 22, 2004 Hmmmm...Perhaps the answer may be to connect the two ends of said wire together? Quote Share this post Link to post Share on other sites
