emmafwa
active spoiler problems
I fitted a new stereo a few weeks ago and since then my active spioler doesnt work!
It works manually but the active part is no longer true.
Ive read another person with the simmilar problem and someone suggested looking at a blue wire behind the ICE, where the hell is that????
Do you think Ive buggered it up by fitting the radio myself? Am I in the right place for a blue wire??
Help will be very much appriciated.
Emma
You're in the right place...
Take out the head unit again, and you'll find a blue wire with a white stripe on it coming out of the car's wiring loom... disconnect this from whatever it's connected to and your spoiler will probably start working again... 8)
Ok now I did what you said and I found two blue wires with white stripes one was connected to something and the other had insulation tape round the end of it ( I definately did not do that), so I disconnected the other and just left it lose, but it still isnt working.
Do you think the "insulation tape" wire has gone wrong futher down the line or should I just take it to the pros'
Thanks very much for the help.
