TonyC 0 Posted October 23, 2004 Apart from the bulbs, what can I check to get my reverse lights working? Thanks in advance.TC Quote Share this post Link to post Share on other sites
ben16v 0 Posted October 23, 2004 IIRC there`s a switch under the gear stick cover that tell`s`em to turn on..... i could be wrong! Quote Share this post Link to post Share on other sites
destructiv dave 0 Posted October 23, 2004 Switch is on the gearbox. Take the connector off and bridge it, if your reverse lights work then it is your switch.. Probably just needs a good cleaning on the contacts. Quote Share this post Link to post Share on other sites
ben16v 0 Posted October 23, 2004 destructiv dave, was nearly right! :oops: :oops: i knew there was a switch at least! Quote Share this post Link to post Share on other sites
TonyC 0 Posted October 25, 2004 Thanks for the advice; the wirings ok as the lights worked with the short. Will test the switch out at the weekend and get hold of a replacement. Cheers, TC Quote Share this post Link to post Share on other sites
