yalan
engine basics - cold exhaust gasses?
can any one tell me what can make a 16v engine's exhaust gasses to blow hot & cold?
Just been to see a car which has a bit of a bouncey idle (when the engines been running 25 mins or so). When I put my hand in the exhaust, the temperature of the gasses went quite clearly from hot to cold to hot every time the idle bounced.
I can't even imagine how this is possible from a hot engine.
??? cheers!
Sounds like it has some "engine problems" matey :shock:
yeah - but I like it ....... !
- financial suicide methinks!
benz.jpg[/img]
yalan, is that a piccy of the car with the problems ??
If it is - don't touch it with a bargepole :wink:
Merc Cosworth parts will cost you a fortune :shock:
even from your guys? - yeah, that is the one. Asking £2K
I was under the impression that it was 90% 190 stock parts......
.... or is it the other 10% (engine parts) which'll break the bank ?
Take my advice m8 (based on 15 year's main dealer experience) Cosworth 190E 2.3-16v will totally break your finances. Especially as this car has unknown engine problems. In good nick, the 2.3-16v "Cosworth" is a very nice car to drive & quick too 8)
190E 2.5-16v - very disappointing to drive in comparrison to the 2.3. The 2.5 is not a Cosworth power plant - it's a Mercedes copy. Engine capacity was increased in an attemp to get a similar power output. On paper, the 2.5 is a quicker car - in practice this is not the case, the 2.3 is way better.
The 16v 190's share surprisingly few parts with the rest of the 190 range - even most of the body panels are different, as are a good proportion of the interior ones.
