B4LJX 0 Posted November 1, 2004 hw do u take this off without causing huge damage? Quote Share this post Link to post Share on other sites
B4LJX 0 Posted November 4, 2004 i have had a good look at this am i right that the whole sun roof has to come off in order to chage the material on it? Quote Share this post Link to post Share on other sites
Bally 0 Posted November 4, 2004 The sunroof trim just clips & slides into the roof.. but if yr dropping the roof lining you'll have to take the trims plastics off too.. Quote Share this post Link to post Share on other sites
B4LJX 0 Posted November 10, 2004 sorry probably just being dense, the roof lining is off, but the material that covers the sunroof the tilt and slide bit, i cant get off, someone give us a step by step wot to do thanks bal Quote Share this post Link to post Share on other sites
Guest Posted November 15, 2004 You should be able to pull it back slightly whilst down (sunroof closed). once you move it back slightly, put the sunroof on tilt. Then it should come away. Nothing to figure out from there you should be able to manage :wink: Quote Share this post Link to post Share on other sites
