swfblade 0 Posted November 2, 2004 A while back i posted that my rear fogs had stopped working, as everytime i put the fronts on, it blew the fuse. Well ive had the fronts apart now, but cant see any reason as to why this would be happening. Someone suggested the fronts shorting out on the casing or summit, but i tries it without the casing on at all, and it still blows the fuse. Anyone got any other ideas? Share this post Link to post Share on other sites
Henny 0 Posted November 2, 2004 take all the bulbs out of all of the fog lamps, and see if it still blows the fuse... If it does, you have one mother of an annoying wiring fault... if it doesn't, replace each bulb in turn, turning it on and then off again in between to make sure there's power getting to the bulb OK... you should then find where the fault is when the fuse blows again.... 8) ...at least, that's how I'd approach it... 8) Share this post Link to post Share on other sites
VR6 0 Posted November 2, 2004 So much for doing a search like you said in this post .... http://the-corrado.net/.archive/forum/viewtopic. ... ht=#136703 ;) We now have 3 different threads about your fogs. Share this post Link to post Share on other sites
stevemac 0 Posted November 2, 2004 Not any more :wink: Share this post Link to post Share on other sites
