Cougar
Clutch pedal brackets moving Normal?
I noticed that when I depress the clutch pedal the whole pedal and bracket seem to deflect about a half inch. The stearing shaft also moves a bit. Is that normal on a G60?
Thanks.
I didn't think so, the assy looks pretty flimsy and I can't find anything loose. I can actually slightly feel when the clutch is depressed through the steering. Strange.
Get under the dash and feel for the rear end of the pedal box, this sits flush against the bulkhead wall it should be so frickin solid that Arnie couldnt move it.
The mount to the firewall is good and solid but the assy seems to move further away from the wall. I did notice that a cross bolt just above the steering shaft seemed to be loose but it looks like it goes through plastic and I'm hesitant to torque it down. Hope there's not a crack in the bracketry somewhere. I'll be checking it soon.
