pablo_vr6
removing wing mirror
Hi,
There are two screws that have to be undone. if u push ur mirror back one way u can undo one of them, then u have to push the mirror back the other way to get to the other one. Then there are two electrical block connections in the door that have to be seperated from the mirror. Mirror should then be off.
Explosives? Hacksaw? Get a friend to hold on to the mirror whilst you drive off? Some sort of freeze-ray?
Sorry I'm not sure of the proper way to get it off, but you never asked for the best way - you just asked how to get it off :D
the heads on the screws will almost certainly be in a bit of a state, make sure you soak 'em in WD40 or Plusgas before even thinking about undoing 'em and use a screwdriver which fits 'em properly else you'll end up having to drill the heads off... (yes, that IS the voice of bitter experience! :oops: )
