jamest
stutter
the vr is stuttering slightly when idling!
not missing a beat or cutting out- just very slight changes and it feels like it might get worse...
or is this the infamous irregular idle- the only thing is that it seems to be getting worse!
could this be the HT leads or the distributer or something like that?
could it benefit from an oil change and some fuel stystem cleaner maybe?
aaaaaaaaaaaaaaaaaaaaargh more expense
Do the cheap things first, clean the ISV and Throttle Body with carb cleaner and change the dizzy cap..
An Oil change is never a bad idea and the same goes for the leads if they are still original.
