Storm
Alrm fitting issue/problem
Having looked behine my fuse board, it appears that the guy who fitted my alarm cut through the 4mm thick wire from the ignition key that goes to the fuse board for the alarms immobilser circuit and cut in with soem 0.5mm stuff.
Can Alarm units switch the amount of current that goes through this circuit or are they supposed to add a relay??
