MrWizard
Hello Fellow Dubbers
Well as of right now She is sitting on a full Eibach Bilstien Suspension. Which I can now say is done. I currently have a blown head gasket :mad:
would love to have some input from every on what should be done while I'm have it worked on. The plan is to go with 12-15 psi S/C boost now this is a good 12-18 months out sence I plan to take the time till then preparing the car for the power increase. SO really I'm still in stages desiding on the setup to go with
The List
LSD
Kyrogenic Syncros 1st,2nd,3rd, Lower ratio 5th need sugestions here
Sachs 6 puck cluth (opinons or sugestion)
Lightened Fly wheel thinkin 11 or 12lbs
Lightened Crank pulley
Oil Cooled (still looking for a brand or model)
new timing chain
head work (not sure heresome thoughts as folllows)
5 or 7 angle valve job titanium retainers & vavle springs
port & polish
Gutted intake manifold
Euro Throtel Body
When the S/C is installed Fuel pump, injectors, head spacer gasket will be addressed at that time
Also what Cams can I run with sence I'm going S/C?
I'm currently at 98K miles let me know if I have missed somthing
Thanks,
Dan
Standard cams are ok with s/c or go for 256 dsr cams or schrick 248s.
Mocal do a good oil cooler kit.
Suggestions:
Replacing oil cooler seals, replacing bits like the thermostat, seals and housing if necessary.
Some good engine mounts: vf-engineering, turn2 or vibratechnics.
If your doing the headgasket now, probably best to go for arp headstuds instead of stretchbolts so you don't have to replace them when you install your spacer gasket.
Big brakes?
Great looking car btw. Is it black or moonlight blue?
Thats a real gorgeous looking C mate, like the inbumper repeaters. the dark pearl green is PERFECT.
Excuse my ignorance, but is this a vr or g60????
