kid corrado
Crazy Horn
when its cold and icy, on turning the ignition the horn sounds and stays on. when the ice melts off the windows and roof as the day warms up the car is fine again. strange. does anyone no what electrics this could be or have encountered anything similar. if so help!!! thanks
AFAIK all the horns get a permanent supply with ign on and the circuit earth is made when you hit the button. So I'd suspect a rogue earth. From your symptoms I'd look at the horn connections first, could have water/ice earthing it down, then work back up the loom. HTH
Damn.
Here's me thinking this was going to be about those "colonel bogey or Dukes of Hazzard" style musical horns. :cuckoo: :mrgreen:
