swfblade 0 Posted December 29, 2004 Im trying to install an oil temp guage into me G60. It comes with a sender and goes from 50 - 150 degrees. To save on hassle, can it be run from the sender thats already in the engine, by simply taking it out from the MFA and plugging it into the guage? (This is assuming that the one in the engine goes to the MFA without going anywhere else!). If so, which wire will it be? I dont have a wiring diagram unfortunatly yet. I had a quick look 2nite when installing my Boost guage, but the wire that came from the sender was green/black, and there was no green/black into the MFA. Quote Share this post Link to post Share on other sites
swfblade 0 Posted January 7, 2005 [schild=19 fontcolor=FF0000 shieldshadow=1]bumpty-bump[/schild] Quote Share this post Link to post Share on other sites
Henny 0 Posted January 7, 2005 it depends on which resistance protocol your new gauge works on. Each manufacturer has a different range of resistances which their dials work on. If the gauge you have is VDO, (or works on the VDO range) then it'll work properly with the original sender. If it's not, then you'll get all sorts of weird and wacky readings off the new gauge... :| Quote Share this post Link to post Share on other sites
20v turbo 0 Posted January 7, 2005 try http://www.lma-group.com ,thats where i got my addapter from for my gauge, think it was only a couple of pounds and didnt take 10mins to fit. Quote Share this post Link to post Share on other sites
Fat Tony 0 Posted January 8, 2005 I'm not sure what you stand to gain from this and why you wouldnt put in an oil pressure or volt meter or boost guage. Or am I missing something here? Quote Share this post Link to post Share on other sites
dubster82 0 Posted January 8, 2005 im missin i too...c ar comes with a temp gauge, id put in oil pressure if i was you along side that boost gauge.... Quote Share this post Link to post Share on other sites
swfblade 0 Posted January 8, 2005 Already have a boost guage, and have a pressure as well. Reson for seperate oil temp is so that I can have the MFA reading on summit else without having to change it to oil the time to check on oil temp. EG. dont wanna start revvin above 3k or so wiv me 65mm pully, b4 me oil has reached a decent temp......I like my charger how it is.... :wink: Quote Share this post Link to post Share on other sites
dubster82 0 Posted January 8, 2005 what you going to have your MFA reading on? The only one i ever use is temp. Surely better with an air fuel ration gauge for a set of 3 ? Quote Share this post Link to post Share on other sites
swfblade 0 Posted January 9, 2005 ok, I appretiate your opinion on this, but i already have an oil temp guage and am trying to install that at the mo, so maybe we can talk about wether or not its worth it when thats done ;) Quote Share this post Link to post Share on other sites
davidwort 0 Posted January 10, 2005 ok, I appretiate your opinion on this, but i already have an oil temp guage and am trying to install that at the mo, so maybe we can talk about wether or not its worth it when thats done ;) I fitted an oil filter housing from a SEAT Toledo (late VW 1.6-2.0 style) and it has three mounting points for oil pressure and temperature senders (instead of my C's original 2), in fact it came with a temp sender on it, on my 16v this meant that the oil temp sender on the head reads the MFA and the second on the oil filter bracket is free for a separate gauge. I swapped the head wiring to the bracket sender and the temp reading was exactly the same at the oil filter housing. The senders all earth through the block, so you can't just attach two wires to one sender I wouldn't have thought. You could always fit a sender inside the car so your MFA gave you the inside and outside temp :) David. Quote Share this post Link to post Share on other sites
Fat Tony 0 Posted January 10, 2005 Thats a fair point. :) Where are you going to mount it? Quote Share this post Link to post Share on other sites
swfblade 0 Posted January 18, 2005 all good thnx guys. replaced standard sender wiv new one for guage, wired it all up last nite and works a charm! now i need to work out what guage i want in the third guage mount. ive fort about oil pressure, but if i can get that middle bit that some have wiv the voltage and pressure on that, then i wont bother and will get a air/fuel ratio job instead. Quote Share this post Link to post Share on other sites
