flusted 0 Posted January 1, 2005 My mfa has stopped working,ive changed swich gear to late mk3gti and it still doesnt work :cry: any ideas? Quote Share this post Link to post Share on other sites
A20 LEE 0 Posted January 1, 2005 My mfa has stopped working,ive changed swich gear to late mk3gti and it still doesnt work :cry: any ideas? broken? :lol: Quote Share this post Link to post Share on other sites
stevemac 0 Posted January 1, 2005 Is it the display that's not working, or a problem with the information that's displayed ? Quote Share this post Link to post Share on other sites
HiAsAKite 0 Posted January 1, 2005 If the mfa display shows garbage or frozen I believe you can reset it by disconnecting the +ve battery terminal and tapping it 5 times on the +ve contact before reconnecting.. ...works with my mk2 golf Quote Share this post Link to post Share on other sites
stevemac 0 Posted January 1, 2005 Could also be that the vacuum pipe into the back of it is leaking or damaged. Quote Share this post Link to post Share on other sites
flusted 0 Posted January 2, 2005 It displays the clock but nothing else.Its as if the switch is disconnected even tho i know its not Quote Share this post Link to post Share on other sites
stevemac 0 Posted January 2, 2005 Is the switch definitely a good one ? Quote Share this post Link to post Share on other sites
flusted 0 Posted January 2, 2005 yeah,it worked in the mk3.when it started playing up,you had to press the switch hard for it to work then it just stopped working Quote Share this post Link to post Share on other sites
stevemac 0 Posted January 3, 2005 Sounds like a faulty switch or possibly a bad connection Quote Share this post Link to post Share on other sites
flusted 0 Posted January 3, 2005 il try another swich,thanks for advice. is it fused Quote Share this post Link to post Share on other sites
stevemac 0 Posted January 3, 2005 It uses the same fuse as the rear spoiler (No.16). Quote Share this post Link to post Share on other sites
