joebloggsVR69 0 Posted January 13, 2005 How's the plastic panel (number 40 in the pic) held onto the boot lid? Clips? Screws? Can't really tell from ETKA - Is item 43 what hold it on, or is that just a number plate fixing screw? :? Quote Share this post Link to post Share on other sites
Blue_Joe 0 Posted January 13, 2005 No item 43 isn't what holds it on. There are 4 (I think its that many) small plastic nuts under the trim inside the boot that hold it on and also trim tape at the bottom of the plastic panel. Once you remove the 4 plastic nuts you need to carefully pull bak the panel and cut away the tape. But be really careful as it breaks so easy! possibly easier to pull off the old one and buy a new one to replace it with! Quote Share this post Link to post Share on other sites
20v turbo 0 Posted January 13, 2005 yep mine broke taking it off,it was the little rubber nuts that broke the plastic posts of the back of the panel when i was undoing them. Quote Share this post Link to post Share on other sites
Henny 0 Posted January 14, 2005 think the nuts are part 22 on that diagram... 8) Quote Share this post Link to post Share on other sites
