Rossco 0 Posted January 16, 2005 I took my servo and mastercylinder out while im doing the swap and gave it a paint and put on a new mastercylinder but when i re-fitted them the pedal doesnt reach the switch that turns off the brake lights. I notice the servo linkage looks like it can be adjusted so im guessing thats what i need to do but i dont understand why its changed as i put the stuff back in as it came out, anyone got any theories?? Quote Share this post Link to post Share on other sites
h100vw 0 Posted January 16, 2005 If you are fitting the original, nothing should have changed. Hook it all up and check it then. The return spring on the pedal will pull the pedal and master cylinder back. Gavin Quote Share this post Link to post Share on other sites
Rossco 0 Posted January 16, 2005 Its all hooked up, the pedal just doesnt go back far enought to press the switch, its not a big gap, about 1mm Quote Share this post Link to post Share on other sites
