Yash 0 Posted January 20, 2005 Hi, Not sure if i'm posting this in the right area but..........I'm getting the water pump on 1.8 16V replaced next tuesday, at the same time i've asked the mechanic to change the cam belt and cam belt tensioner. I'll also be buying a new power steering belt and alternator belt, my question is what other parts should i get replaced at the same time. I've got a good mechanic but he's not a corrado specialist so he doesnt know what other parts are prone to wearing out that I might as well replace now. Any help much appreciated. Thanks, Yash Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 20, 2005 Other side of the engine but you may want to get the cam chains replaced with the cambelt... Quote Share this post Link to post Share on other sites
Henny 0 Posted January 20, 2005 that's quite a big job there Supercharged, Personally I'd wait until you need to do the headgasket, or at least the tappets need changing before attacking a Valver's chain... 8) Quote Share this post Link to post Share on other sites
bighands 0 Posted January 20, 2005 Need this done on mine 2, how much is this gunna cane my pocket roughly ?!? Quote Share this post Link to post Share on other sites
Henny 0 Posted January 20, 2005 what? the cam chain? It's about £12 for the chain (IIRC) and a fair chunk of labour... (inlet manifold off, rocker cover off, cams out, re-time it all and re-assemble using new gaskets...) Not difficult, just time consuming... :| Quote Share this post Link to post Share on other sites
bighands 0 Posted January 20, 2005 no sorry, the cam belt, i wince every time i floor it! Quote Share this post Link to post Share on other sites
Yash 0 Posted January 20, 2005 i'm paying £100 for cam belt and water pump but then hes our local friendly mechanic. Henny, do u think its not worth me replacing the cam chains then? Just dont wanna do any major damage to the engine by not replacing them. Any other suggestions as to what else is worth doing at the same time? Quote Share this post Link to post Share on other sites
Henny 0 Posted January 20, 2005 I've never heard of a cam chain breaking on a valver... it's only a tiny little chain which drives the inlet cam off the exhaust cam which is driven by the cam belt, so there's sod all strain put on it... Like I say, I'd only change it if you've got the inlet manifold off anyway.... 8) If that's £100 including labour, that's not a bad price... 8) Parts to do: cambelt (duh!) belt tensioner P/S belt (it's gotta come off, so you may as well do it!) Get the mechanic to check the tightness of the crank bolt while he's in there too... 8) Quote Share this post Link to post Share on other sites
Yash 0 Posted January 20, 2005 cheers henny, Its 100 labour only, have to buy the parts myself. Quote Share this post Link to post Share on other sites
Henny 0 Posted January 20, 2005 parts won't cost you more than £50 to £60 if you go to Euro or GSF... 8) £100 labour only's still not a bad price to be honest... you're looking about 2 to 3 hours to do the waterpump and cam belt... 8) Quote Share this post Link to post Share on other sites
Yash 0 Posted January 21, 2005 Thanks for the input. Gonna go down GSF at lunchtime and get the parts luckily GSF is a 2 minute drive from where i work. Euros is close to about 10 mins, my office is in the perfect location for C owners seeing as parts are always needing replacing. :roll: Quote Share this post Link to post Share on other sites
