A20 LEE
Best Place for Drilled Rear Disks?
Need to order drilled rear disks to match my fronts, any suggestions on suppliers and price? Are bearings supplied with the disks?
I don't know of anyone who supplies bearings WITH disks as a normal thing. Most places that sell the disks can get the bearings though... ;)
Don't forget to get the new ABS cages too else you'll have a bright orange light inside your nice interior to annoy the hell out of you! :lol:
j dub........HELP. THat happened to me. I got my wioshboen driveshaft and discs replaced
Orange light nice and bright..all the time.whats an abs cage? where do i goet it?
re: rear brake discs
German swedish do brembo and zimmermans for about 25 buc each. only prob is that the one i went to had vented zimmermans, Wheel bearing kit i think is 20 buc
khurrado, the ABS cage is only on the rear wheels, so it's a different problem you have, 'cos you bent the front suspension on yours IIRC...
khurrado, I thought it was you that hit a curb and bent the front suspension on his car, sorry if I was mistaken... :oops:
Rears? German swedish do brembo and zimmermans for about 25 buc each. Wheel bearing kit i think is 20 buc
Drilled Zimmermanns are slightly more expensive tho... :(
Lee - give me a shout if you need the bearings, we keep 2 different qualities under different part numbers.
