raypau
Sparkplugs
Am going to soon replace my sparkplugs, is anyone using iridium sparks? German car specialists wanted to charge £25 per plug!!!
For anyone whois using them, do you see any difference? Apart from the fact that they are £5 more than the standard sparks.
Response much appreciated.
Cheers
Ray
I wouldn't do it unless you go turbo or SC. I would just stick to the standard factory plugs.
I am running the Denso plugs on SC'ed motor.
IK 20 for normal motors
IK 22 for forced induction motors
i'm using iridiums in my storm.........but only because with having a schrick i needed ones with a long service life......so that i'm not having to have the schrick apart every year to change plugs...........not noticed any problems with them at all............pre-schrick i just used the standard NGK's
Its Denso IK16 for standard motors.
IK20 for IF for daily driving use
IK22 for a lot of high end use!
I use IK22 :twisted: but havent had them in long enough to be able to rate them, they do seem to give a bit more power, but it is a bit lumpy and flat until the plugs warm up.
I have Denso Iridiums in my golf, don't notice any difference with them or anything just thought they looked well cool so I bought a set on ebay.
OK, looks like i will stick with the standard plugs as apart from looks there appears to be no concernible difference.
Cheers for the response
How can a 0,4mm tip not look 8), :lol:
Damn straight! :lol:
Check this shit out 8) :D
