markymark 0 Posted January 26, 2005 I've got a thick scratch about 20cm long above the rear wheel arch on my red C. 1. Is there any trick to prevent rust in the short term (ie anyone know of anything i can put on it in the meantime to prevent further corrosion)? 2. WHat the best/most economical way of getting it sorted? Is it poss to buy touchup paint/spraypaint/'pen'? Can you still get matching colours for a 1994 Corrado? All advice/help much appreciated! THanks Quote Share this post Link to post Share on other sites
Ford 0 Posted January 26, 2005 Yep can still get touch up pens for C's, just pop into VW (under a fiver), I bought touch up pack last year you get paint and lacure in a pack. Cover scratch as a temporary measure anyway and to prevent rust, depends how bad it is. Might be worth saving some pennies and getting it into a bodyshop. I am still saving and waiting for some better weather before I do mine. Quote Share this post Link to post Share on other sites
Henny 0 Posted January 26, 2005 is this a straight red, or a metallic/pearlescent? If it's straight red (it'll be Flash if it's a '94) you can still get the touch up pens from VAG which will be a bloody good match... Get a primer pen from somewhere like Halfords and put a layer of that into the scratch, then a few thin layers of the touch up... build it up until it's slightly proud and then buff it back with a good quality cutting compound and you should be able to get it to dissapear! 8) (at least, that's how I did it on my first Tornado red Corrado ;) ) Quote Share this post Link to post Share on other sites
markymark 0 Posted January 28, 2005 Thanks alot for that guys. have bought the paint and will get to it. Just out of unexperienced curiosity - when you say 'pop into VW' - what do you mean? A VW dealer? (or are there place you can go to buy from vw direct?) ta. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 28, 2005 just go to the dealer, there cheaper and better quality... Quote Share this post Link to post Share on other sites
