biggerbigben 0 Posted January 31, 2005 Hi all, Spent the weekend working on the C's electric’s, I'm pretty happy with the progress I made but I came across a couple of problems, I've fitted Passat door handles and I tried the central locking but the doors kept locking but didn't 'unlock', the boot was fine. I took the mechanisms off and modified it a little more because I thought the handles didn't open the doors properly but that wasn't the problem. I then unplugged the solenoids and tried to synchronise the central locking system, I did this about 4 times and it still didn't work. My question is - has anyone had similar problems or knows what’s going on!!!! It seems like the vacum isn't pulling for long enough and thus not unlocking the doors. Could I have a vacum leak or is it the handles and new mech being a bit stiff?? I did check both these areas but they seemed fine! I can't get the wing mirrors to work or the driver’s window either if anyone has any ideas on them; otherwise most of the other electric’s now works! Missing a couple of looms but that shouldn't be a problem. Any help is much appreciated!!! cheers Ben Quote Share this post Link to post Share on other sites
VR6 0 Posted January 31, 2005 Moving to Exterior.. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 31, 2005 I take it you were using the Passat mechs as wwell as the handles (middle part number should be 839 NOT 837 on both handles and mechs) Quote Share this post Link to post Share on other sites
flusted 0 Posted January 31, 2005 I had the same prob with mirrors and windows not working.It was 1 wire had no live,il try and look at what colour it was and let you know Quote Share this post Link to post Share on other sites
biggerbigben 0 Posted February 1, 2005 I had the same prob with mirrors and windows not working.It was 1 wire had no live,il try and look at what colour it was and let you know that would be good mate, thanks.. B Quote Share this post Link to post Share on other sites
biggerbigben 0 Posted February 1, 2005 I take it you were using the Passat mechs as wwell as the handles (middle part number should be 839 NOT 837 on both handles and mechs) I do have the matching latches, they worked fine opening and shutting the doors before I brought the central locking into the equation!! Might pop the old ones back on and see if that works... Quote Share this post Link to post Share on other sites
