Big-ted 0 Posted February 2, 2005 Hey guys, I've just been reading the buyers guide on here, and it mentions that if the MFA resets on turning the ignition off the car may have been clocked. Is this true? I tend to leave mine on "1", and if I turn the ignition off for a reasonoble time (couple of hours) channel 1 will reset. Meanwhile, data is held in channel 2 no probs. Is this normal? The mileage on my car seems to be consistent with the history from the last 5 or 6 years.... Quote Share this post Link to post Share on other sites
The Hub 0 Posted February 2, 2005 I think I remember reading some where that Channel 1 is for your most recent trip and Channel 2 is for overall figures. Meaning that Channel 1 is supposed to reset if the car is not used for a number of Hours. I am sure someone else in will clear this up, but I dont think you need to worry about the car being clock cause of this. HTH Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted February 2, 2005 I think I remember reading some where that Channel 1 is for your most recent trip and Channel 2 is for overall figures. Meaning that Channel 1 is supposed to reset if the car is not used for a number of Hours. I am sure someone else in will clear this up, but I dont think you need to worry about the car being clock cause of this. HTH yep thats right mate Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted February 2, 2005 the first one does single journeys the second is accumulative :-) Quote Share this post Link to post Share on other sites
stevemac 0 Posted February 2, 2005 The first one is not intended just for single journeys - it has a timed reset - it resets to zero 2 hours after the car was last used, regardless of how many journeys the car has done. The second is accumulative. Both can be manually reset by holding the position switch in it's extreme left or right position for a couple of seconds. Quote Share this post Link to post Share on other sites
The Hub 0 Posted February 2, 2005 I knew someone would explain it properly, just wasnt sure how long it took to reset. Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted February 2, 2005 then what is it intended for ? surely its used for a single journey if it is used Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted February 2, 2005 The Hub, yeah right :-) stevemac, The first one is not intended just for single journeys from the corrado handbook......... note the single journey Quote Share this post Link to post Share on other sites
stevemac 0 Posted February 2, 2005 GIXXERUK, Try it & see .. Note the part about the "single journey" being resumed within 2 hours .. :shock: Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted February 2, 2005 vw call it the single journey memory and i never suggested it resets every stop but you said "The first one is not intended just for single journeys " which is wrong or vw are Quote Share this post Link to post Share on other sites
stevemac 0 Posted February 2, 2005 I ain't getting involved in an argument here - just consider this - you make 2 journeys, one journey begins 1.5 hours after the other. Do you class both as a single journey ? I don't & I suspect neither would you. The MFA, however, would. My post above was to clarify Big-ted's original question, which I think I did. Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted February 2, 2005 there isnt an argument jeez , you got it wrong and had a dig thats all if you were going to make 2 journeys, one journey begins 1.5 hours after the other, then you would reset it ...simple thats why its called that Quote Share this post Link to post Share on other sites
stevemac 0 Posted February 3, 2005 GIXXERUK, I got what wrong ? Quote Share this post Link to post Share on other sites
The Hub 0 Posted February 3, 2005 Have to say i am with stevemac, on this one. It's a computer it will only do whats it programmed to do, and that is to reset after every 2 hours of being used, regardless. Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted February 3, 2005 stevemac, The first one is not intended just for single journeys its called the single journey memory which gives its use away slightly ----------------------------------------------------------- stevemac, I ain't getting involved in an argument here - just consider this - you make 2 journeys, one journey begins 1.5 hours after the other 2 journeys ? then it isnt a single journey ! and you would reset it you must see it dude ? Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted February 3, 2005 The Hub, wouldnt happen to be because he's a mod would it ??? jeez read it the post !!!!!!!!!!! It's a computer it will only do whats it programmed to do, and that is to reset after every 2 hours regardless. it doesnt reset every 2 hrs !!!!!!!!! Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted February 3, 2005 why is this sooo difficult it resets after the car is left for 2 hours , after you have made your single journey ! so now the hub tell me why you are with steve ?? or your motive to back steve Quote Share this post Link to post Share on other sites
The Hub 0 Posted February 3, 2005 Nothing to do with Stevemac being a Mod, i dont know the bloke, just my point of view. I think the author has got his answer so lets just leave it there :) Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted February 3, 2005 :-) you know you were wrong to agree :-) otherwise you would have explained why you agreed, why can no one say doh!! i was wrong there :roll: Quote Share this post Link to post Share on other sites
The Hub 0 Posted February 3, 2005 Have to say i am with stevemac, on this one. It's a computer it will only do whats it programmed to do, and that is to reset after every 2 hours of being used, regardless. Sorry but I had edited my original post but still agree with Stevemac. Anyway :lol: Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted February 3, 2005 tell me why you agree ?? tell why it resetting every two hours makes any difference i'm sure you dont know Quote Share this post Link to post Share on other sites
The Hub 0 Posted February 3, 2005 Cause it isnt just a single journey, you can make 2 or three and the data will be stored for all as long as there isnt a 2 hour break between any of them. I really can't believe we are talking about this :roll: Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted February 3, 2005 just cant see why you cant see it VW call it a single journey memory if you make 2 or 3 journeys without a two hour break then you reset it Quote Share this post Link to post Share on other sites
The Hub 0 Posted February 3, 2005 Yeah you being the user, but the MFA wont reset it as thats what it's programmed for, so really it's not a single journey memory Quote Share this post Link to post Share on other sites
