potatonet
Short shifter for corrado's
Just FYI B&M Short shift kit works for all corrados. Item number 45106. It is a cable shifter for the new VW's with cable shift tranny's
Good to know. Picking one up ASAP.
Did you install one? If you did...how is it? I was contemplating the Neuspeed one also.
no the neuspeed one is the stock one modified, just like the dieselgeek one. the B&M is about 4 times stronger if you like shifting hard, even though its not good for the corrado. also the B&M has a lifetime warranty and works sooo much better than stock. I have seen one on a passat and felt the shift difference its like night and day. I am buying one in a week. it just feels more solid.
i realise this topic is about 100 years old.
but can anyone confirm the part numbers are correct? thanks
also did you buy/fit one in the end
You can't install it from inside the car, like the instructions suggest (generic Golf based), you have to drop the exhaust and a panel above it to get access to the gear change mechanism. Trust me, I tried! B&M used to imported to the UK by Eibach UK but Eibach has now transfered this product to Graham Goode in Leicester. Give them a shout, it looked like excellent kit but I couldn't be bothered to drop the exhaust etc..
