SleekG60
Got my self a FMIC for my G60!!
I have one but i have posted on vortex how to put it it on piping wise but i was told i need to find a Rare U bent pip that comes off the charger and that not many places can bend this and they say that they see this pipe on German e-bay has anyone seen one or knows where i can get one and possibly a cost and a pick that i can see what this looks like.
Thanx :D
you mean the one from a rallye golf G60? the one that costs way too much to buy from VW. make it yourself, you will have one hell of a time mounting it to the charger though because anything has to have a bolt going through it. my suggestion get an RSR outlet and then get a bent hose from samco or a bent metal tubing, 3"
by the way does anyone have part number 191 145 755, I am in the states and am looking for one, I want to do my own front mount IC. Sorry sleek G60. whoever has one PM me
ASk G-man what the bend is so you can get a custom bit of samco... something like136 deg.
these U bends were also fitted to the NON-air-con Golf G60s too... (that's where mine came from! ;) )
IIRC, There's 4 major bits you need with it.
1) The U bend
2) The gasket
3) A smaller support bar (replaces the black support bar which bolts between the charger and the block which won't fit anymore due to the U bend being in the way)
4) The 2 bolts. One which bolts straight throught the Ubend and into the charger outlet, the other which holds the support bar on.
its ok i think i am gonna do the samco deal that sounds good or if anyone has more than one of those pm me and potatonet..... thanx for the help :thumbleft:
Just to let you guys know, I believe that Samco now do a 180 deg. U-bend in silicon which you could use to come off the RSR outlet (have seen pictures of this so I know it exists),
Cheers,
BigEastSideVWG60
