g60Dazzaman
Coolant Issues
There is too much pressure in my coolant system, Stevemac told me that their is probably a block in the system somewhere, does anyone know any sort of product i can stick in the system to free it up?
Yes but what to flush it out with? Is it a case where i need to take the water system to bits or is their a product available that will free up a blockage?
Flush it out with water from a hose, you can get a chemical to use first but not sure what it's called. The blockage in cooling systems generally appear in the radiator so just back flush it to see what appears.
I have used Wynn's cooling system flush on all-iron engines with good results. However, I haven't tried it on lumps with alloy heads... anyone know if it's a really bad idea?
Cheers,
Olly
Cheers,
Olly
I think you could dislodge some muck only for it to get stuck somewhere more critical, I don't like oil or coolant flush chemicals for this reason on old engines, fine if you regularly use it on a newish one.
David.
Fair point, although in the engine I used it on it doesn't just break big chunks free - it breaks the bits down to a size where they probably wouldn't get stuck anywhere. This seems like a better idea than just trying to move stuff around with water?
I'm just a bit paranoid about the chemicals attacking the head.
Olly
