mariovr6
blue anti freeze?
i think i need to put anti freeze in my vr but today the vw shops are closed so i cant get the pink stuff! would it be ok putting some blue anti freeze for this week?
should only put in g12+ or g12 as far as im aware...although someone with a little bit more knowledge will correct me im sure :)
If you have gat the original G12 or G11 in there you should not mix one with the other sort!! - they will form a gel
G12+ can be mixed with anything.
Either change the lot or top up with water for now!
cheers
only reason i was thinking about the blue stuff was for tonight as it might get colder n i leave for work at 6am ............
it dont look pink any more coz ive added water so many times!!!
wait til monday n get the good stuff!!!
  Quote
What's G12+?
G12+ is all the dealers sell now (over here anways), it's just an improved version of G12 as they found it caused some corrosion and can be mixed safely with G11 and G12.
