Saul 0 Posted February 23, 2005 Hi All The heater on my 1990 16v Corrado stops working (blowing hot air) after 20mins or so ,especially in slow town traffic, any ideas why ? It will start working again if I stop the car and leave it for a while. Cheers Saul Quote Share this post Link to post Share on other sites
Supercharged 2 Posted February 23, 2005 Does it stop blowing completly or blows cold air?? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted February 23, 2005 Air lock maybe? - when you say in traffic, does the water temp go up or down at all? Quote Share this post Link to post Share on other sites
Saul 0 Posted February 23, 2005 No, water temp seems OK. One thing I thought it might be is a valve that is attached to the water hoeses in the engine bay before they go into the heater matrix, think it is some kind of safety valve, I had one quit on a mk II Golf Gti, in that case it just closed and the heater would not work at all. cheers Saul Quote Share this post Link to post Share on other sites
Supercharged 2 Posted February 23, 2005 Yeah, I think they close if the matrix loses pressure (ie has a leak) not sure if they could stick closed and then open again, maybe worth changing the valves if you think the matrix is ok and refreshing the coolant. Quote Share this post Link to post Share on other sites
Saul 0 Posted February 23, 2005 Thanks, do you know if the valve works on temperature ? Quote Share this post Link to post Share on other sites
RACK 0 Posted February 24, 2005 The same has happened on my G60. Not good in this weather! Quote Share this post Link to post Share on other sites
Rossco 0 Posted February 24, 2005 yeh apparently these valves are quite prone to failing, i think this has happened on my G60 as well Quote Share this post Link to post Share on other sites
RACK 0 Posted February 24, 2005 Anyone got a pic of the valves? Also are they a pain to fix? Quote Share this post Link to post Share on other sites
Henny 0 Posted February 25, 2005 they're pretty easy to replace (if a little expensive) You just need to disconnect the 4 hoses and connect 'em to the new valves. It's the BIG chunk just by the bulkhead in the engine bay with the 4 waterpipes connected to it, 2 of which go through the bulkhead just to the right of the head as you look at it from the front of the car. You CAN'T miss it! ;) Quote Share this post Link to post Share on other sites
